Old May 18, 2017 | 03:39 PM
JHM2K's Avatar
JHM2K
Default Re: 17/18 inch wheels for SRT-6?
Originally Posted by ATX SRT-6
The 225/40-18 tires on the front are really stretched on that 8.5" wide rim. I'm not sure what the widest tire that will fit on the front before rubbing, 245?
Correct, 245/35 is the widest you can go on the front w/o rubbing, and that needs to be on <32mm offset. So, +35mm offset might actually allow for some rubbing.
I stuck with the 225/40 on mine and had no issues. Flat-spotting is very common on high-performance summer tires, especially if you allow them to get cold in the same spot after aggressive driving.
I would stick with XL load rating. SL is mathematically fine but the confidence in the tire suffers because they have a higher tendency to "squirm" under cornering loads.
Continental has a new tire out which has been getting VERY good feedback on the Mercedes forums:
https://www.tirerack.com/tires/tires...re=735YR9ECSXL
VERY reasonable too.
