Old May 18, 2017 | 04:10 PM
  #5153 (permalink)
Kurtp13's Avatar
Kurtp13
You will need to remove the wiper arms and the plastic cowl.
You will find tons of leaves and debris underneath clogging the 4 drains.
Use a coat hanger to GENTLY clear the drains ( don't knock off the rubber tubes underneath )
Eventually this can cause water to pour in through the fan hole and soak your amplifier and TCM,
not to mention ruining the fan motor and resistor board..
What about using a shop vac, would that work? Or is it too large or powerful?
