Old Jul 26, 2006 | 04:23 PM
HDDP's Avatar
HDDP
Default Re: disable ESP for dyno mode
Originally Posted by feets
I know that a couple folks are trying a work around to get the cars into dyno mode and it's peaked my interest.
I've arranged to have one of our Mercedes shop foremen plug into my SRT to see what can be done. Assuming it works, I've got a few things I'd like to try.
1) does it completely disable ESP/BAS/ABS/ETC or do those functions still work.
2) will the vehicle stay in dyno mode after multiple restarts.
3) can we map the steps necessary and repeat them on a hand held scanner instead of the Mercedes diagnostic equipment.
4) are there any visible indications when the car is in dyno mode.
HDDP: do you want ESP to remain active in it's reduced "off" mode or would you prefer it to be disabled?
What other things would you guys care to look at?
Did you find anything out ? Did you try anything ? Did you speak with your Mercedes Guru ? Or was your post just a bunch of hot air ? Updates !!!
