Old May 19, 2017 | 12:14 PM
garjoe05's Avatar
garjoe05
Default Re: Sloppy steering...FIXED
Can the bolt under the dash be used to straighten a slightly crooked steering wheel ? In other words, if the steering wheel isn't exactly level when going straight. So if that bolt is loosened, it allows the steering wheel to move independent of the shaft while being adjusted ? That sounds crazy dangerous if people find that loose occasionally ! My wheel is ever so slightly off, and I am thinking of checking to make sure the bolt is tight in the first place (for safety), then seeing if I can make a slight adjustment.
