Old May 19, 2017 | 01:58 PM
amx1397
Default Re: free just pay shipping
Now that I have a pair of guibos ( giubos , flex disks, whatever ).
Guess I'll have to look into replacing my 75,000 miles ones.
I read somewhere on the net that you should 'grease up' the metal inserts , but those suckers seem to be made into the disks and will not move at all.
Anyone dealt with this ?
George they do move ,, three stick out on one side and the other three on the other side. they adjust when installed before you remove yours or as you remove look at them, once installed in the car the inserts do not move. they are held tight by the bolts. if you remove the bolts on the center bearing , the pry forward the drive shaft with coupling , then the front one is easy, if I can help give me a call. jim
