JHM2K
I'd keep the PSI near 35 to compensate for the added sidewall, but you will love the stability that comes from the width.
I checked the tire pressure today and found it a little high, within a pound of 40psi on all tires. I saw the sticker on the door jamb says 36psi is recommended, so I lowered it to 36psi.
I was thinking of setting it at 34psi, but I wonder if that might be a bit low for tires with 35 & 40 aspect ratios.
The Conti DW's that are on the car now are considered a "max performance summer" tire. The car has been parked for a couple of weeks, and I took it out today after re-installing the 3rd brakelight... man, it
DOES take some miles before the parking flat spots come out!!
Thanks again for all the comments and info!!
Nikko
