ala_xfire
You will need to remove the wiper arms and the plastic cowl.
You will find tons of leaves and debris underneath clogging the 4 drains.y
Use a coat hanger to GENTLY clear the drains ( don't knock off the rubber tubes underneath )
Eventually this can cause water to pour in through the fan hole and soak your amplifier and TCM,
not to mention ruining the fan motor and resistor board..
Do you think that the transmission dip stick could be used to run through the drains or are there bends in the drain hoses that are to tight for it.
With the $6 investment in a dip stick it would be nice to get some more use out of it.
