Old May 23, 2017 | 08:30 AM
GraphiteGhost
Default Re: installed new alarm siren and no chirp or alarm
Originally Posted by bhindzioncurtain
Bit the bullet and started on uncovering the CLP/SSM. What a pain, removed all the black clips with some tools I bought at Dealextreme. "ZIQIAO Auto Car Radio Door Clip Panel Trim Dash Audio Removal Installer Pry Tool - Orange ZIQIAO Auto Car Radio Door Clip Panel Trim" only costs 2.83 but it comes from China so allow up to three weeks.
Then I removed both of the fabric covered panels and after 20 minutes figured out how to remove the black plastic piece connected to the latch area. Had to remove the white panel from the drivers side and noticed two of the white clips were smashed, probably from when it was assembled. I ended up breaking one. So found a youtube clip where someone had modified clips for an Infinity to work on Crossfires. I am not sure about the guidelines for linking so just will give you the title "How-To Video of Modified Trim Panel Clips Chrysler Crossfire.AVI" this video was from 2008 but I am sure Infinity's still use the same clips for the older ones. I think he said less than $3 for 4 clips. So tomorrow I will be checking on getting me a few.
Finally was able to pull the Styrofoam inserts out and found evidence of prior water stains on the drivers side.
The passenger part really depressed me. There is 1/2 inch of water sitting in the area so I am guessing the CLP/SSM is shot.
My question is instead of doing all the work of taking apart the wing and the gas filler door why wouldn't it work to just caulk those areas? They make clear caulk and it seems to be the easy way to fix this problem. Even with taking those areas apart and putting sealer in there, eventually they will probably still leak some time in the future. If I am looking at this wrong please enlighten me.
Sorry you got hit with the 'water in the bottom' issue! I cut an 'X' in the rubber plugs on the lowest point (on both sides). IF water gets in there, it'll just weep/drain out before filling up. I cut the 'X' in a way that when water pressure is on it, it'll 'bow' down and drain. Good luck finding or fixing your CLP/SSM module!
