Old May 28, 2017 | 11:37 PM
onehundred80
Default Re: SRT 6 Supercharger
Originally Posted by Tar Heel David
My crossfire SRT 6 automatic coupe has only 23k miles and has the folling proble.
I was having intermittent cut off of my supercharger and replaced the intercooler pump with a Bosch pump from NeedsWings. I contacted Needswings and was told to check air intake and it should be around 100f. Mine is about 200f, the same as the coolant. How can air intake be at 100f when coolant is 200f and they are using the same coolant?
I feel a surge in the car and then the supercharge cuts out. It then will come back on without having done anything. Then cuts off again without surge.
Any suggestions.
Just for the record, where are you measuring intake air temperature? Before or after the intercooler?
Is it possible that the IC pump is working intermittently due to a bad contact or a bad IA temperature sensor?
Is it working the same or better since the new pump was fitted?
