Tar Heel David
Got my letters confused for testing. Should be obd2.
Seems like either your pump is not running or you have an air lock and the coolant is not circulating. You need to bleed air from the circuit. Search for the pump always on mod. Then you can check for flow with the engine off. That's where I would start.
