Old Jun 1, 2017 | 04:13 PM
GraphiteGhost
Default Re: installed new alarm siren and no chirp or alarm
Originally Posted by bhindzioncurtain
Got the CLP/SSM installed with a covered foam case. Noticed that the foam really soaks up the water, took it almost three weeks to dry out. I covered the foam case with plastic then used Pipe Wrap Insulation Tape " to help with sound deadening. didn't stick too good so taped it down with duct tape. Not worried about condensation or air flow since I left that big slice open that the wires and pump hose goes through. See Picture
I messaged the person I bought the pump from and they found me a Tow Alarm, ten of the white clips, 10 of the black clips, and a couple of the metal clips. Only going to cost $35 for the whole bunch. Got lucky.
I still say before you put that all together, slice an 'X' into both left and right forward rubber grommets in the bottom of the 'trunk'. Make sure they pop through to the outside. Don't remove any rubber, just slice them in a 'X' pattern. This way, if water intrudes again, it will drain out before damaging anything.
