Old Jun 2, 2017 | 09:43 AM
  #38 (permalink)
GraphiteGhost
Default Re: installed new alarm siren and no chirp or alarm
Originally Posted by bhindzioncurtain
I'm open to trying that but as tight as the plugs are in the holes how does that work. Wouldn't it just seal up after you made you cuts. Do you use an exacto knife and how long of cuts? I am guessing you have put everything back together, did you take any pictures?
I was considering popping out the pugs and then using the RTV to glue a little piece of aluminum screen to the bottom of the trunk.
I used a single edged razor cutting from one side to the other starting in the middle (reversing for the other leg of the first cut). Then do the same from the center of the first cut, completing the 'X'. I wouldn't pop out the plugs but if you want to do that remember little bugs can come up through those screens AND you might get some 'splash' mud and crap in there. The 'X's on mine do not let anything in but lets water drain out (they are stiff enough as to not 'droop' in the center). Whatever way you choose to do it, just remember if you completely remove them plugs, you might have issues with what you install.
