Old Jun 6, 2017 | 10:27 AM
tunaglove's Avatar
tunaglove
Default P0505 troubleshoot help!
Ever since I installed catless downpipes I have been getting a P0505 code. Can someone give me some info on a normal idle state?
Using an OBD reader I'm seeing this:
Throttle 0%
Idle in Park: 735 rpm
Idle in Drive: 550 rpm (give or take a little)
This is when the car is at full temp. I clear the code and it seems to trip after the car gets to 190F.
Also when moving the gas pedal slightly rpms increase but I don't see any throttle position change for the first 1/16th inch of pedal movement. I have removed the supercharger and replaced all the gaskets again, then pressure tested for leaks. Found none. Waste of time it runs exactly the same.
The car starts and runs great. Smooth power, idle sounds perfect to my ears. If the check engine light didn't come on I would not think there is a problem.
Can some of you guys look and see what your car is doing at idle so I can compare?
THANK YOU.
