Re: P0505 troubleshoot help!
Hi
The idle speeds sound ok, but I'm not sure that it's actually an idle control problem (as indicated by the code). Did you turn off the "rear oxygen sensor diagnosis" in the ECU when you fitted the new downpipes? It sounds like the ECU is going into closed loop mode when it reaches 190 and doesn't like what it's seeing. Just my guess, anyone else got any ideas?
