onehundred80
Plugs are not there normally for no reason, plug it in and see what happens.
Maybe you will give some feedback to this question as you never did to the other two.
I tried to plug the white and black connectors under the seat together, no go, they are both female ends, is there an juction connector to connect these together? the blue connector from the seat motor is pluged in the blue connector under the seat, the seat will not move front or back. Is there a separate seat relay for the passenger seat under the dash below the steering wheel or is there only one shared by both seats. need to know what is up with this seat not moving front or back.
