Getting to blower control switch Back
Jun 12, 2017 | 01:37 PM
permalink
onehundred80
Apr 2006
25,432
647
Ontario
Re: Getting to blower control switch Back
Quote:
ala_xfire
The radio is removed by using the 2 removal keys in the two vertical slots in the faceplate.
You can pick up a set of universal keys at Walmart.
The slots are horizontal by the way.
Remove the radio and unplug it.
Undo the two screws that are now just visible where the top front edge of the radio was. You should then be able to use a trim tool to carefully pry the bezel off starting at the top corners.
I'll add a couple of pictures to give you an idea.
01:52 PM
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
