Old Jun 16, 2017 | 12:38 PM
  #300 (permalink)
K Grainger's Avatar
K Grainger
Default Re: Crankshaft Position Sensor
Changed out the CPS this morning but marginal increase in how it is running. Checked the RCM and solder all looks good If you rev it up at RPM's it seems to run smooth but has a hard time idling and will stall. The exhaust smells of very bad gas!!! Only a 1/4 of a tank in it. Should I try drain the fuel or add some clean fresh fuel and try it ?
