Steve Jr
That's a totally different set up than mine. Mine is quite comical , when you see how it works. Next time I remove it I'll post a picture. When you see it , you go "huh".
While your there, will you do something for me? Put it in place , then see if you can reach in where you pulled the radio out , just to see if you can replace the bulb from there. I can do it on mine, I just want to see if that how it's designed for all.
Ooops,
wrong square hole, it fit perfectly but I can't see any purpose when I put 12v to the car
with light switch on the bulb kights up but is not seen in the tray
the only opening to the tray is in the center of this photo, but it is small and rectangular, those plastic posts almost look like a housing plugs into them?
I'm thinking that previous dealership busy fingers lost or broke something while in there when owned by another.
Sure, I will be happy to check that out for you if i get it right and reinstalled in the console.
am i posting in the right forum?
i expected some feedback on this one, ummm
Thanks
