Steve Jr
That's a totally different set up than mine. Mine is quite comical , when you see how it works. Next time I remove it I'll post a picture. When you see it , you go "huh".
While your there, will you do something for me? Put it in place , then see if you can reach in where you pulled the radio out , just to see if you can replace the bulb from there. I can do it on mine, I just want to see if that how it's designed for all.
Yepp, no problem to pull that bulb out and replace, through the radio opening. make sure the tabs on the connector face left to right looking at the console and shown in the pic. My finger is sticking in that square mounting hole for the bulb with my arm through the radio opening.
