Thread: Alarm Question
Old Jun 22, 2017 | 10:33 AM
GraphiteGhost
Default Re: Alarm Question
Originally Posted by Gregm
Here is what I know --- disconnected the siren and no more surprise screaming problems. The only check I did was push the Panic button on the remote to see what happens. When I push the Panic button the lights flash and when I push it again the lights stop flashing.
Here is what I suggest, make sure you do not have water in the lower part of the 'trunk/hatch'. Another thing to 'consider', when that siren WAS triggered, was the lights flashing (as they should be)? If so, and the alarm is still tripping (without the siren, as modded), is there still a problem (like the lights flashing), and what is CAUSING it? I would suggest you check for that water in the lower back compartment, if it is the source of your problem, it'll only get worse and a lot more expensive if that module gets ruined.
