Old Jun 29, 2017 | 06:07 PM
onehundred80
Default Re: Hard shift into 3rd gear...
Originally Posted by Stefwan
For real. I guess I should have been more detailed in my update. I did jack it up and look underneath at the plug. It looked fine, no sign of a leak. Well I didn't check it, that was one of the things my regular mechanic checked with me. I did the reset myself and it didn't make a difference, a bit smoother(?)on the 1->2 and 2->3, but it could have been wishful thinking, and the major jump was still there at around 40-45 kmh. And I'm not mechanical. I can do like an oil change, and I was really hyped to tackle the brakes myself later this summer. I don't even know if I can get it high enough to remove the transmission. The idea of doing the valve sleeves and springs and draining the pan and doing a filter I was prepared for, if a bit intimidated. But I'd still have to drop around 150 in parts for the master sleeve overhaul kit from sonnax, and a new filter, possibly a new gasket(if I mangled the rubber one taking it off) and then the 4 or 5 dollar springs from MB. All before any fluid replacement, and it may do nothing. And I guess that's where if I was willing to go for it, I might find that's the issue. Solve the whole thing for 1/10th the cost of a rebuild....if it is the problem, of course. I still got an issue with a light that goes on and off on the rear driver side marking and parking light. And the brakes were safetied, but I want to upgrade them when I change them, maybe paint the callipers. And I might do a wrap to change the colour, fix a foggy headlight. Minor **** I'm gonna DIY. And I plan to use this forum. But transmissions just scare me off. It sucks, and if I was willing to wait I could prolly build upto doing it. I feel you guys. It kills me. But a transmission as my first major auto DIY repair? Man, why can't it be like, a new control arm or bushings or something?
Spend the money it's not mine and the economy needs a kick in the ar$e.
But before you do that have you or anybody else checked the tranny fluid level? The connector may have been changed before you got your hands on the car but nobody checked the fluid level.
There is no dipstick you have make something that goes down that filler tube after you remove the plug at the top.
Big Daddy, a member here, is in Ottawa, send him a PM and ask his opinion, he knows more than most and certainly more than some dumb a$$ mechanic that you seem to have asked so far. Remember he said $2,500 minimum and that will surely go up even if he finds an oil and filter change will do the trick.
