Old Jul 6, 2017 | 04:11 PM
Delcobob's Avatar
Delcobob
Default Re: Locking/unlocking issues
p
The weak spot is the air line that enters the trunk lid. It breaks inside the corrugated tube that the hose passes through on its way to the trunk lid latch. This line is flexed every time the trunk lid is opened, replace the hose if you can with urethane hose not vinyl hose. This weak spot is on the coupe and roadster.
Checked that spot in the convoluted tubing and it checked out okay, but thanks because I can now see where it would fatigue there. So next I used a pair of needle nose vice grip to pinch off the 2 lines where they "tee". First pinching off the line to trunk latch made no change in door latch, but pinched off line to door
latch and trunk latch started working! So now my leak is between tee and door latch. I think I'll start inside the door.
