Old Jul 17, 2017 | 08:29 PM
oledoc2u
Default Re: crossfire rear tires
Originally Posted by jrhack
They did the soaking with detergent. The problem was the Ridge of the tire would not close enough on the rim to allow the seal so they could pump air into it. They mounted, unmounted, used lots of tools to try and get the lip of the tire to seat into the rim so they could inflate. It just looks like the RF are too rigid at that size.
Sorry if I missed it. Are you mounting on the stock rims? If so, they should fit. It isn't easy and it does require some patience. Mounted over 6 sets for my cars in the last 8 yrs. I only mounted 1 pair of run flats. They were Goodyear F1's. I would never run them again. The stiff side walls are NOT good for tractions. I can spin the crap out of them.
