Old Jul 21, 2017 | 12:23 PM
onehundred80
Default Re: Smaller water pump pulley
Originally Posted by chuK_138
I have an aluminum 115mm water pump pulley I cut myself. Still plenty of meat left on the sidewall to trim off 2-3mm off the diameter. I ran it for a few weeks and cut a smaller one, but it made about 15 passes at the track and spun true. You can see the belt mark on the pic attached.
I hope it is made better than the LET pump pulleys, they failed quickly due to the rads being too small, the bolt faces shattered as well.
CLICK
Another case of the quick buck being more important than part testing, some members forgave the maker for the poor design.
Aluminum is a cheap and easy material to machine, but it is prone to failure much sooner, see the aluminum SC pulleys for more proof.
