What about fishing a wire snake down the neck to see if hits obstructions?
May not be a good idea 🤔 the center check valve opens going toward the tank and if you push a wire past it the flap will close on The Wire trying to pull it back and you will not be able to pull the wire out or tear the flap up. 😬
