Re: Christmas comes early, warning lights everywhere
Kingdav1954
I revert back to my original thoughts I think a connector has lost continuity and it's just a matter of unplugging cleaning and reassembly and I believe that would fix the problem, the cab would be a good place to start and while you're at it I would do the same for body control module and powertrain control module. Be sure to disconnect the ground cable first.
Check out Section 8E page 92 very informative. I think the logical place to start is at the 4-wheel speed sensors, I think it would be a good idea to visually inspect each one disconnect each connector clean and reconnect then take it for a drive so that the system has time to reset itself if that doesn't work move on to each subsequent component in the system disconnecting and reconnecting.
Reason: Correction
