Updated the CRP (thanks ala xfire). Ran it again.
Codes and Readout
Transmission - P2404 The stop lamp switch signal sent from the traction system via the CAN bus is implausible.
ESP - 1018-000 The fault code is not found in the database.
Did some searching and found P2404
here. However, I don't know what that means or what to fix.
I can not find anything on the ESP fault code 1018-000. The traction light on the speedo does not come on and I can't not turn off BAS/ESP with the button.
The CRP won't read the Airbag DTC. It goes into the Hint screen and stalls, nothing happens.
