Old Aug 3, 2017 | 07:59 PM
waldig's Avatar
waldig
Talking Re: Recurring car meets in DMV area
Dont know if you have this info, for what its worth till wednesday.woody
What does that mean? This diagnostic trouble code (DTC) is a generic powertrain code, which means that it applies to OBD-II equipped vehicles. Although generic, the specific repair steps may vary depending on make/model. The EVAP (Evaporative Emissions) System allows fuel tank vapors to be purged into the engine and burnt rather than expelled into the atmosphere as harmful emissions. The EVAP system contains a pressure sensor to check the integrity of the system. Periodically, the EVAP system performs a pressure test to check that there are no leaks in the system. It uses this sensor, also known as a fuel tank pressure (FTP) sensor to check for leaks. Basically P0453 means the PCM (Powertrain Control Module) noticed the EVAP Pressure sensor or FTP is indicating a higher than normal pressure (above 4.5 Volts) in the EVAP system. NOTE: On some vehicles the FTP is a part of the fuel pump assembly in the tank. Related evaporative emission trouble codes include P0450, P0451, P0452, P0454, P0455, P0456, P0457, P0458, and P0459.
Read more at: https://www.obd-codes.com/p0453
Copyright OBD-Codes.com
