Old Aug 4, 2017 | 12:51 PM
HOT FIYA's Avatar
HOT FIYA
Default Re: Recurring car meets in DMV area
Originally Posted by waldig
Dont know if you have this info, for what its worth till wednesday.woody
What does that mean? This diagnostic trouble code (DTC) is a generic powertrain code, which means that it applies to OBD-II equipped vehicles. Although generic, the specific repair steps may vary depending on make/model. The EVAP (Evaporative Emissions) System allows fuel tank vapors to be purged into the engine and burnt rather than expelled into the atmosphere as harmful emissions. The EVAP system contains a pressure sensor to check the integrity of the system. Periodically, the EVAP system performs a pressure test to check that there are no leaks in the system. It uses this sensor, also known as a fuel tank pressure (FTP) sensor to check for leaks. Basically P0453 means the PCM (Powertrain Control Module) noticed the EVAP Pressure sensor or FTP is indicating a higher than normal pressure (above 4.5 Volts) in the EVAP system. NOTE: On some vehicles the FTP is a part of the fuel pump assembly in the tank. Related evaporative emission trouble codes include P0450, P0451, P0452, P0454, P0455, P0456, P0457, P0458, and P0459.
Read more at: https://www.obd-codes.com/p0453
Copyright OBD-Codes.com
Thanks Woody. Yeah I've read into the code, but it seems that there are several things that can cause it. I'm guessing it's either the fuel pressure sensor or the relay wire that attaches to the sensor itself going bad. I'm going to go ahead and replace both just to be safe.
