Old Aug 4, 2017 | 06:38 PM
onehundred80
Default Re: Interior Door Pull Handle Repair/Retrofit with Pics
Originally Posted by Gtsman
Hello gentleman. Need some help. What is the preferred tool to use when separating the stainless trim on the interior door pull. Mine is on pretty good and I do not want to damage or scratch it. I am upgrading my door speakers. Any suggestions would be appreciated and I thank you in advance.
If you look at the seam on the bottom with a mirror you can see that the lip that is folded under the rear lip has some notches in it. You can pry it apart carefully at those gaps. I carefully used a thin screwdriver to separate the two halves. Separate the two halves evenly a bit at a time. Easy does it is the way to go. It
