Old Aug 7, 2017 | 09:28 AM
onehundred80
Default Re: WTB -- ignition housing
Originally Posted by curtisr
Dear 180,
I am truly appreciative of your encouragement and have a question for you. Is it the key cylinder (I'm thinking brass projections) or the housing itself or something else that is the source of sticky key difficulties?
Thanks again!
Roger
The cylinder is not the source of the sticky key, the problem is a little spring operated pin that binds up inside the housing. Pry open the little cover, remove the pin and spring and you are done.
You can see this operation in the how to that is listed and also in a UTube video made by Big Daddy costarring Super Mario. Easy peasy.
Naturally the cylinder could cause problems but I have never heard of them here.
