Old Aug 8, 2017 | 01:51 PM
onehundred80
Default Re: Side Mirror Help Please
Originally Posted by HOT FIYA
Sorry to bump such an old thread but I figured this would be a better alternative to started a new thread entirely. What is the process to removing the side mirror? I recently obtained a new rubber trim ring that goes at the base of the mirror (mine was old and starting to deteriorate) so I need to remove the mirror to install it. Any tips?
Rotating the whole mirror into the position where it is against the window exposes two screws. Take them out and the mirror is loose, I think you then disconnect the wires .you can then add the new seal.
