Old Aug 9, 2017 | 07:08 PM
onehundred80
Default Re: Side Mirror Help Please
Originally Posted by HOT FIYA
Ok so removing the bolts for the side-mirror was a cakewalk. But where do you disconnect the cable for the power mirror? Looks like it may be a job where you have to remove the interior door panel Why can't anything just ever be simple with these cars?
If I remember correctly you will see a grommet around the wires where they go into the door. Pull the grommet out of the door and pull the wire out of the door. You should find a plug and socket that you can separate. Do not let the wire go back into the door or you will have to take of the inner panel.
Here is the Mopar PDF on how to install signalling mirrors on the Crossfire. You are only doing the first few steps.
Realize that you would not have to leave the mirror hanging on the wires while you removed the inner panel, so the connector is easy to get to.
CLICK
