Old Aug 9, 2017 | 09:16 PM
Sussudio's Avatar
Sussudio
Default Re: Side Mirror Help Please
Originally Posted by HOT FIYA
Ok so removing the bolts for the side-mirror was a cakewalk. But where do you disconnect the cable for the power mirror? Looks like it may be a job where you have to remove the interior door panel Why can't anything just ever be simple with these cars?
When you open the door you should see a square panel on the inside which you can pop off and the connector is right there. Disconnect it and you should be able to pull the connector thru the outer hole. I just did this about a week ago.
