Ok great. I'll check it out today. Thanks for the feedback.
Sussudio
When you open the door you should see a square panel on the inside which you can pop off and the connector is right there. Disconnect it and you should be able to pull the connector thru the outer hole. I just did this about a week ago.
onehundred80
If I remember correctly you will see a grommet around the wires where they go into the door. Pull the grommet out of the door and pull the wire out of the door. You should find a plug and socket that you can separate. Do not let the wire go back into the door or you will have to take of the inner panel.
Here is the Mopar PDF on how to install signalling mirrors on the Crossfire. You are only doing the first few steps.
Realize that you would not have to leave the mirror hanging on the wires while you removed the inner panel, so the connector is easy to get to.
CLICK
