Re: This stinks and maybe it will help you
So I had the cloth all sagging and i couldn't drive like that. So i removed the headliner and cleaned the foam from the board and from the cloth and re-sprayed it back on using 3m super 77. LOL it looks horrible LOL but I had to go on a trip and didnt have time to get it professionally done or buy the replacement cloth. I am thinking of getting it done professionally as its very hard to put the cloth back on without having bubbles. I got one side nicely done but the other side i half assed it and it has bubble. I am just saying it can be done if you know what you are doing. Probably a 3 to 4 hour job. I find putting it from one side to another is easier and do small parts of 6 inches of cloth at time.
FYI the 2 pins in the back has two part to it. There a small pin which needs to be pulled out to release the lock and when putting back you need to keep the pin out and put the base in and then push the pin in. Wish I knew this before wasted tons of energy and time taking those off.
