Old Aug 22, 2017 | 06:30 PM
RJ557's Avatar
RJ557
Default Re: NEED Drive SHAFT Center Support (bearing?)
Originally Posted by goykgo
Hi guys
I need a drive shaft center support ( maybe called hang bearing?)
for 2004 crossfire auto
Please help me finding the part or let me know if you have one.
Thanks,
goykgo@gmail.com
I just had the carrier bearing replaced on my 2006 Crossfire and it eliminated the shaft thumping on the tunnel and significantly reduced driveline noise at highway speed. I purchased the replacement bearing for $30 and labor to replace it was $175. The shop was able to pull the driveshaft without dropping the exhaust. They stated the job was simple and straight forward however a rack is required to do the job.
