MrFastSRT
Thank you. Folks, keep in mind I have an SRT6, so the air pump location is on the drivers fender well. I am not sure where the ground terminal is, but my guess is it is the grouping of wires in the corner of the below picture. I removed and cleaned the connectors and terminal. Reset codes. The next day in the morning the air pump went on as usual. When I got to work, there was the P0410 code pending.
The the repair manual holds many secrets, 😉 that with diligent study will lead you on the path of enlightenment.
