Old Aug 27, 2017 | 05:11 PM
onehundred80
Default Re: Alarm keeps going off...
Originally Posted by Lisad
ok, here'so what I did to fix the problem:
Pulled all of the rear panels and foam out. Exposing everything including the rear passenger wheel well modules. Yes, take the insulation around modules out, too. They need to be exposed. Wait for many Sunny, Dry days in a row. When you've parked your car, be sure to manually raise the spoiler and Crack your windows about 1". Do this for a week...or for at least 7 sunny, dry days. PROBLEM SOLVED.
ALSO, NEVER RAISE SPOILER WHEN GOING THROUGH CAR WASH (touch less of course) NOR IF YOU ARE HAND WASHING AND RINSING WITH HOSE. When the spoiler is UP, water cones streaming into the wheel wells.
The aforementioned solved my issue. Good luck, let me know.
It might be tough to sell your car on this forum now that you have admitted to a trunk that leaks like a sieve. The solution to your problem is posted on this forum. The leak should not happen when the spoiler is up or down.
