Old Aug 28, 2017 | 03:40 AM
maggy55's Avatar
maggy55
Question Ecm immobilizer ignition ?
I just want to make sure I understand the SKREEM process. Ok , the key itself is just mechanical and turns the ignition switch. The RFD chip in the fob communicates with the SKREEM module behind the instrument panel through the antenna ring around the ignition. If the RFD chip has the same code as the chip in the SKREEM , it sends the code to the ECU. If the code is the same as on the chip in the ECU then it will allow the car to start. Is that about right, or am I missing something?
