Old Sep 1, 2017 | 09:46 PM
Steve Jr's Avatar
Steve Jr
Default Re: 2004 crossfire starting issue
You're on the track , I would be going in. Since you've done the pump an filter ,with the high milage(that's a factor) maybe run some Seafoam through the system to clean the injectors. Have you done a reset for the throttle? Sometimes it gets use to a driving pattern , an this would set it back , to what it should be.
