Old Sep 13, 2017 | 11:35 AM
JEFASOLD's Avatar
JEFASOLD
Default Re: Strakes removal with good results?
The strakes are removable by fishing line or plastic scraper to lift the double sided tape, then using a plastic trim removal tool, lift the front of the strake up. There are 3 pins that go in three holes. Then you can twist the strake up or down a little and work the back 3 pins out. These have a barbed fastener but can be worked out as the hole they are in is elongated. Just take your time.
