Preventive maintenance on CPS etc
Sep 13, 2017 | 02:09 PM
permalink
onehundred80
Apr 2006
25,432
650
Ontario
Re: Preventive maintenance on CPS etc
Quote:
crossvic
Thanks for your concise answer
Could you please confirm the Bosch P/N:
CPS: 0 261 210 170
Camshaft PS: 0 232 103 037
Torx bolt is M6x16 and E8 socket to unscrew it.
Around 100 € for both.
Thanks in advance.
Those are the numbers, the camshaft position sensor does not fail very often, replacing parts sometimes means you install a part that fails almost immediately. Bosch parts are the best, we say use Bosch parts or you will walk home one day.
Carry spares of these parts and the tools required to install them.
Solder the weak joints as shown in the RCM repair thread just in case they are poor joints and look at the contacts on the relays for signs of arcing, replace the solenoids if the contacts are burnt.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
