Re: 6 Spd problems
Slightly off topic...Should the shifter be centered in the opening when its in neutral?
I just changed my shift **** and it doesn't look centered.
I'm not sure if its because the **** is smaller then stock.
If you push the shifter straight forward from
neutral it should go to 3rd gear, correct?
