Old Sep 16, 2017 | 09:18 PM
tighed1's Avatar
tighed1
Default Re: Not start crossfire
Crank and no start is usually the crankshaft position sensor. Check to see if she has a fault code as the CPS throws a code. The fuel relay could also be an issue.
Turn the key to the ON position.
As soon as you turn the key on you should hear the fuel pump run for a couple of seconds.
Check for codes and report back.
