Old Sep 21, 2017 | 07:35 PM
James1549
Default Re: Exterior driver's door lock?
So here is what I learned today after the mailman delivered.
The lock cylinder can be removed from the handle assembly using a drift punch to remove two pins. See pics.
If you need a new door handle, the cylinder can be switched out so your same key will work.
The right and left pull handles are the same.
