Thread: We're in!!!!
Old Sep 23, 2017 | 08:06 AM
onehundred80
Default Re: Were in!!!!
Originally Posted by Kingdav1954
Congratulations and welcome to the Forum, concerning the crayon smell what you need to do is change your cabin filter it has gotten wet and probably full of debris you know Leaf litter. Use the search bar and type in cabin filter and it should explain how to change it, you can order them online or you can buy them from most Parts houses like AutoZone, advance, NAPA Auto Parts. If you need any help don't hesitate to ask.
Changing the filter will not do it, Waldig said the smell went when he changed the headliner and used another type of cement (3M) to hold the headliner in place. Others have said the smell comes from the carpet. These cars use environmentally safe adhesives and that seemingly is the cause of the crayon odour.
The filter does make a smell if it is damp, always use an activated charcoal filter for the best results. If the filter is getting wet, look at the drainage vents under the cowl and clear out any debris under there while you are at it.
