Old Sep 25, 2017 | 10:35 PM
Tcrit51's Avatar
Tcrit51
Default Re: Half of the dash warning lights suddenly put along with the speedometer
After 4.5 hours, I tried to restart. The first time, it did nothing, however the next time I turned the key it started as if nothing was wrong. Started it 5 more times, and it started flawlessly as though nothing had ever been wrong - no warning lights, nothing. Almost sounds like the crank sensor might be bad?? At least now, I can, hopefully, drive it to the mechanic to check for error codes. I think you might also be right about the traction control sensor. Will check into that as well. Thanks for the help.
