Old Sep 27, 2017 | 06:37 PM
onehundred80
Default Re: Fog light adjustment
You young whippersnapper, I was not really trying to be a smart ***, I was trying to say that you really don't need to know which way to turn the screw, the results will instantly show you if you are turning it the right way.
I guess I could go out in the garage and try it, but I just didn't feel that the effort was worth it.
Besides, "I" don't really need to know, I'll just continue to do the turn-it-and-see method.
( at least I responded to your post, nobody else did )
The good Samaritan often gets a kick in the Goolies for his efforts, I have found that out. Evidently the use of logic hurts, seemingly more than the resulting kick.
Clockwise is the direction to make the the light go down, a little stretch of the imagination should find the answer requested.
A Torx #20 fits but the actual size may be a size larger as the #20 is a bit loose.
