Old Sep 29, 2017 | 09:35 AM
onehundred80
Default Re: Differential Noise?
Originally Posted by Scout
I have a 2007 Coupe and there is a LOT of noise coming from the rear end of the car. Not sure if it is from the differential or if anyone knows what it might be. It is a roar that gets louder as speed is increased.
My car was noisy when I got it and new tires solved the problem. It could also be the rear wheel bearings or the shafts. There is probably less chance it is the differential.
If the tires have a saw tooth wear pattern or something similar it may well be the tires. Internal tire damage also makes a noise as well.
